coil pack or something else
Old 11-12-2005, 07:59 PM
bodydropped's Avatar
Default coil pack or something else
My car has dead miss,but if I rev it up a few times it gos away.I just changed my plugs like 3000 miles ago,and i used ac delco platnuims.Does this sound like a coil pack going bad?
Old 11-12-2005, 08:55 PM
horist's Avatar
any SES lights? A coil pack will set an SES ....
Old 11-12-2005, 09:27 PM
Billiumss's Avatar
What year is your car, how many miles? Do you have a K&N filter? If so, did you recently clean it?
Make sure all your spark plug wires are "clicked" on.
Have someone run a msifire test on all 8 cylinders.
Old 11-13-2005, 01:41 PM
my car is a 98 with 72,000 and i did just clean my k&n air filter
Old 11-14-2005, 10:39 AM
ttt.....
Old 12-03-2005, 08:40 AM
pantz28's Avatar
I have the same problem right now. I'm hoping it's not the coil pack cause I'm broke and christmas is right around the corner. Switch the coil pack to another cylinder and see if it follows, if yes, then it's the coil pack.
Old 12-03-2005, 09:15 AM
Big_Brother's Avatar
Simplest way to ID the missing cylinder is through the scanner, watch the misfire counters. Once you know which cylinder it's just a matter of checking spark and fuel to that cylinder, and that there is not a vacuum leak close to that cylinder (misfire at idle) If the cylinder has adequate spark and fuel, that only leaves compression (valve timing will not factor into a single cylinder misfire)
