A4 tranny problems, wont shift!! help
ok.. after a 20 roll punch, my rebuilt 4l60e (under a year old) wont shift out of gear unless i let off the gas completely... i can give it light throttle and even bring it all the way up to the rev limiter. it has a good tune and a 3800 stall converter. when i can get it to shift it will still pull hard through the gears so i dont think its the tranny.. any type of help or input will help thanks.
Originally Posted by hellbents10
Do you have full manual control but it will not move when in drive.
i think it is the tune, you might have your mph to high for the shift point, and it won't let it shift, or vice versa, i get it mixed up, but i keep having to play with my tune to get mine to work right. some people say you can lower your shift points to around 5500 and get it to shift based on your mph, but i havent tried that. but that might be a couple of things for you to look at
ive had it tuned around three months ago and the shift point was set at 6k. its shifted perfect until last night. it wont shift in full manual either. could it be a modualtor or something? or does it sound like the tranny is going?
I think your clucthes are going...who rebuilt it?
have you r car scanned and come back and tell us the results.
if you need a rebuild and are close to chicago I have a guy that builds bad *** trannies
i broke the band in the tranny, and the three four clutches were gone... $1200 later i should be back on the road i guess u gotta do what u gatta do..
ok the band that was in there was a dupont kevlar band and the trannny shop is going to install a "high energy" band..id rather him find another kevlar one but i just broke a kelvlar one so i guess try something new,, is there a differecne between the two??? also he is taking out the pwmand giving me some shift kit to give me 0-100% converter lock-up instead of having to build pressure to lock up. it already has a b&m kit and a yank 3600. have u ever heard of this kit??
