Tailshaft info needed...
Restricted User
I swapped from my old 4L60E to a TH350 ( and loving it so far). But, always something right. I dont have the speedo hooked up and do not want to do the VSS to WSS. I want to know if the stock tailshaft with reluctor wheel will fit the TH350 or not. I contacted Rossler, who built the trans, for the tailshaft adapter stuff, but forgot to ask. I still have the stock trans, as it has a billet servo and this that and the other stuff in it, but blown clutches and steels. So, if the tails can be swapped, then I will do that.
Charlie
Charlie
Restricted User
Damn it, sounds like another dead end search. Jason, if you happen to find out, please post for me. The other option is I buy the Rossler tailshaft w/ reluctor $250. I do have the 9" tailshaft also.
I had a spacer on a th350 back in '04 but never found out any info on it. Anyone? Im trying to keep my ABS and speedo working.
Is it this one?
http://www.teckpak-fitzall.com/datasheets/7q-35b.pdf
or
http://advanceadapters.com/product/2322/50-0405.html
or
http://advanceadapters.com/product/2...M-VSS-Kit.html
I found a pic of the th350 i used to have. You can barely see it in the lower right hand corner...
Is it this one?
or
or
