2.08 intake valve on 370
By no means 370 is small displacement. 2.08 will be fine on that motor. As a matter of fact I wouldn't use anything smaller than 2.05's. That motor will move some good amount of air. Bore size will not shroud the intake valve.
alright. I already bought the heads, but then i was reading about most people going with the 2.55, and i wasnt sure if there was something wrong with goin with 2.08s. Also, Is there a writeup on the molding clay method to check valve clearance?
