View Poll Results: Did you keep your AIR when you installed headers?
Yes
47
23.15%
No
156
76.85%
Voters: 203. You may not vote on this poll
Did you keep your AIR?
Old 11-14-2005, 11:46 AM
ShevrolayZ28's Avatar
Default Did you keep your AIR?
Do you regret your decision?
ShevrolayZ28 is offline
Old 11-14-2005, 11:57 AM
tim99ws6's Avatar
I didn't keep it. What is to regret? It cleans up the engine bay, and has no ill affect on the motor....
tim99ws6 is offline
Old 11-14-2005, 11:59 AM
jmm98LS1's Avatar
Sure makes spark plug changes a bunch easier with all that crap outta there....
jmm98LS1 is offline
Old 11-14-2005, 01:58 PM
conan's Avatar
conan is offline
Old 11-14-2005, 02:13 PM
TRMIN8R's Avatar
I took mine out, looks much better......
TRMIN8R is offline
Old 11-14-2005, 02:16 PM
Getting a huge fine or failing inspection would be considered regretful.
Old 11-14-2005, 02:17 PM
akZ28's Avatar
Took it off, Have no regrets
akZ28 is offline
Old 11-14-2005, 02:20 PM
2001 White Ws6's Avatar
Took it off...no regrets. Cleaner engine bay.
2001 White Ws6 is offline
Old 11-14-2005, 02:28 PM
LS69TA's Avatar
I'll be losing mine as well when I put headers on.
LS69TA is offline
Old 11-14-2005, 02:53 PM
bgloworm22's Avatar
I have no cats, so why keep the AIR pump!? You'll only fail emissions if you are throwing SES code or if they do a visual inspection. It make the engine bay look better too!
bgloworm22 is offline
Old 11-14-2005, 03:03 PM
Viper's Avatar
No cats, no AIR.
In Ohio you can get collector plates - no testing
Viper is offline
Old 11-14-2005, 03:07 PM
Azhigher's Avatar
Nope, I dropped it when I put on the LT's. No need, engine looks cleaner.
Azhigher is offline
Old 11-14-2005, 03:13 PM
67Ranger's Avatar
i took mine out, and i'm about to do headers. Dont have any regrets yet.
67Ranger is offline
Old 11-14-2005, 03:17 PM
MrDude_1's Avatar
my friend regretted getting the AIR tube option.
we were in his car, and i said, "hey, i can hear a exhaust leak"
we get to his house and look underhood... the AIR pipe in the #1 exhaust port had started to come off.. you could see the blue fire going down the exhaust pipe.
he ended up breaking it off and having someone weld over teh hole...
plus, EVERYONE i know with headers, has eventually taken the AIR off.. so they now have useless tubes with blockoff plates.
just stay two steps ahead and get it without AIR... remove the pump. delete the codes in the PCM, and you'll be set. even if they look underhood, its not like it looks like something is missing.. the engine obviously doesnt have a "smog pump"....
MrDude_1 is offline
Old 11-14-2005, 04:20 PM
WsSickLs6's Avatar
where i am there may be a hard time passing emissions, but like someone said - there is no smog pump to be seen, so if some tubes were removed nobody would really know...Just make sure you're EGR and Cats are there if you want to pass...I can't get inspected because I have no EGR on my 01...but it's listed in emissions control devices that it's supposed to be there
WsSickLs6 is offline
Old 11-14-2005, 08:04 PM
tripps's Avatar
i'll also be taking mine off whenever i put my headers on. it doesnt really serve any purpose, plus, like everyone has stated, makes the engine bay alot cleaner.
tripps is offline
Old 11-14-2005, 08:12 PM
AKIRA's Avatar
****, I dont know if mine are still on. I put in little block off plates in tubes on top of the header, so I dont think I took them off.
Is removing the AIR going to give any performance?
AKIRA is offline
Old 11-14-2005, 08:16 PM
1BadMoFo's Avatar
take it out.
1BadMoFo is offline
Old 11-14-2005, 08:34 PM
No. There is no performance gain except for weight reduction, if you've removed AIR associated parts, that is...
The car will emmit more polutants @ cold start.
Old 11-14-2005, 08:43 PM
code4's Avatar
Removed mine when I did the LT install, I would not have that crud in my car again especially with headers.
code4 is offline
