No 2nd, 1st pops out, 4th grinds - HELP!
The tranny apparently wasn't in very good shape when I bought it.
Now I can go into 2nd, but it just spins without catching. If I am coasting in neutral and shift into 4th it will grind. It doesn't matter if I have my foot pounding the clutch all of the way in or not, it will grind. Sometimes it will not go into 1st when I am stopped at a light, and other times it will pop out when I hit the gas.
I think I have the record for most messed up T56. Help...please....
We can get your tranny rebuilt for you to survive a ton of horsepower. $1,450.00 to have it fully rebuilt with high performance pieces replacing all the weak factory ones. We charge $350.00 to remove and replace the tranny, should you need someone else to R&R it. Bob
