Suspension & Brakes - 100+mph braking?
View Full Version : 100+mph braking?
2001 White Ws6
11-14-2005, 02:32 PM
When i apply the brakes over 100mph it seems they have no stopping power at all, like they are glazed up and don't grip the rotor. Do they always feel like that at those speeds?
I have Hawk HPS pads up front with stock rotors.
Shane_G
11-14-2005, 03:11 PM
I have the carbotec XP9's and I'll have to upload a video of me racing a car this weekend. I went from 120 to 70 in about two seconds..well, it felt like that anyway.
:lurk:
BlueSS346
11-14-2005, 09:49 PM
I have the same pads with Eradi Speed rotors. How old are your pads? You could also try some sloted rotors to allow the gas between the pad and rotor to escape, that could be the glazed feeling your experiencing.
98boxer
11-14-2005, 10:01 PM
I don't have hawk pads, I have car quest performance pads and one time I was going 70 then I decided to keep giving it more gas and I was about 110 and the dam light up in front turned red :bang: I had about blocks to stop before I hit the cars waiting at the light.
Well I tap on the brake easy, I thought hey, I got enough room to not use the brake excessivly. But I was wrong. :( After about half a block I started apply heavyly on the brake and dam car would not seem to slow down. I thought shit, Im going to have to go out onto the side of the road and take the fence thats their with me, instead of hitting the cars in front of me.
Well, luckly, very lucky :chug: The car started to hold brake and slow the car down and I didn't have to crash onto the side fence.
I know I learned my lesson to never speed so fast to where I don't have a bit more the two blocks to stop going over 100mph.
Were you just out on a run or where you racing?
2001 White Ws6
11-14-2005, 10:26 PM
Less then a year old.
2001 White Ws6
11-14-2005, 10:30 PM
It was just a run...no racing.
I got the same feeling but i had plenty of room to slow down. I first braked like normal and at first they seemed to grab but then lost it right after that. This isn't the first time but this time i remembered and posted to see if anyone had in input on it.
Only thing is if it slips my mind and i'm up at those speeds and really do need to slow down if that happens i'm screwed.
SS2win
11-15-2005, 10:56 PM
Stock brakes didnt do much for me at 140. kinda scary when your stopping distance is nearly twice what instinct tell ya. the C5 calipers are much more predictable...
OKcruising
11-15-2005, 11:09 PM
if ya got distance, you could try hittin brakes for a few, letting off for a bit, then gettin on em for a few. kinda like if it doesn't have abs sorta(trying to describe like on-off interval). Try some slotted rotors (not drilled) and aftermarket pads and see if that doesn't help a bunch.
The 04 Silverado's are just plain horrible braking(more than once) with rims from 100+. I could cook steak an eggs for me and friends off those badboys. That feeling of lack of brakes is kinda sickly feelin ain't it.
Humming Bird
11-16-2005, 06:58 PM
yeah i have stock breaks and above 130 they feel scary as hell lol. i feel like they're covered in oil at high speed.
HioSSilver
11-18-2005, 11:41 PM
Get some PFC pads and braided lines for your brakes and don't be scared to way lay on the brake pedal. Stop like you mean it, don't just ease down on the brake pedal 'cause that will just put unnessasary heat in the brakes but don't stab them either. Use PFC pads or you might as well not use any pads at all.
roy
11-19-2005, 11:13 AM
If your having brake problem , I would get it check out , it could be something as simple as the caliper guide pins need cleaning and lubing. As for the HPS pads , they should be fine, I friends over herein germany running that pad on race tracks 15minutes at a time, seeing speeds up to 120mph and braking down to 60 mph with no problem.
zamboxl
11-19-2005, 11:23 AM
i thought the c5 calipers where basically the same as the f bods, exept they run a slightly bigger rotor so it allows for it. plz correct me if iam wrong i would like to know for sure!
speedyhawk101
11-22-2005, 10:10 AM
I live in Germany and HAD the same problem when driving on the Autobahn. I bought EBC front dimpled and slotted rotors along with the RED stuff ceramic pads. It solved all my brake fade problems. I have no problem jamming the brakes at speeds of 160MPH
It's all about getting the expandling gasses and crap a place to escape.
trackbird
11-22-2005, 10:37 AM
It's actually about actually putting decent pads on the car. You changed pads (a big deal) and rotors (not a big deal) and credit the rotors with the performance gains. If you try those pads on a "blank" rotor, you'll find that they work the same.
Bombguy99z28
11-22-2005, 10:42 AM
I don't know, when I had stock brakes I had a brake or die situation @ 120. I stood on the brakes, ABS engaged, I was chirping the fronts, smoke was everywhere, I slowed down real freaking quick. Every single loose item in the car was either under the pedals or at the front of the dash.
Cop Car
11-22-2005, 12:19 PM
think how fast those rotors are spinning... so insane to think about
the stock rotors hot spot so easily because they just let everything stay, slotted rotors allow the pads to breath and not clog up or glaze over. you might want to try to rough up your pads though. drive backwards and apply the brake and do that a few times and see if that helps
roy
11-22-2005, 12:26 PM
I give up :bang:
trackbird
11-22-2005, 12:37 PM
I give up :bang:
Me too.
fa63
11-23-2005, 02:09 AM
Me too.
:jest:
One day, they will learn (or NOT).
2001 White Ws6
11-23-2005, 07:23 AM
I thought Hawk HPS pads were pretty good...so EBC would work much better for what i'm wanting to improve on?
Bombguy99z28
11-23-2005, 11:43 AM
lol... I put AFR heads and new plug wires on my car, those plug wires really got me some power ;)
:jest:
1LoudTA
11-27-2005, 11:59 AM
its funny how fast you approach things at 100+ isn't it?!
LTSpeed
11-27-2005, 01:58 PM
I'd strongly suggest you guys pay attention to trackbird--the guy knows what he's talking about. Dimpled/Slotted rotors are for show. If you want to stop quick, you need to either increase friction with a different pad, or apply more force--like with big brake kits. It's just Physics 101.
My LT1 stops from 100-0 in 330-350ft with C5 brakes/XP8 pads. With the stock LT1 setup, it was around 480-500ft. With slotted rotors on the LT1 setup it was--you guessed it: 480-500ft--right up until the cracked!
mitchntx
11-28-2005, 07:37 AM
Urinating on the brakes will keep them cool as well. However I wouldn't recommend that nor would I takes Cop Car's advice :eek2:
Me too.
I did a while back ... :jest:
But it is, sometimes, rather entertaining ... :engarde:
Mojave
11-28-2005, 09:33 AM
Wow. That is quite possibly the worst advice ever. Could you please explain to me how slotted or drilled rotors help with modern brake pads that don't produce gasses? And how does driving backwards affect anything?
If HPS aren't enough for you, you might consider stepping up to a more aggressive pad, such as the HP+. More noise, more dust, more rotor wear, but also more stopping power and less fade.
The C5 upgrade will also help, if you dont mind going to 17" wheels (and have ~$1000 to drop on it).
trackbird
11-28-2005, 10:47 AM
Well, the tires on our cars rotate 806 times a mile, so at 60 mph, the rotor is doing 806 rpm. At 120 mph, it's doing 1,612 rpm, at 180 mph, it's doing 2,418 rpm. Not really insane....
I'm guessing you are thinking of the old way to adjust drum brakes (drive backwards and hit the brakes to operate the self adjusters). It won't work on this car.....
mitchntx
11-28-2005, 01:28 PM
Yeah, but it is an interesting way to eject a stuck CD ... :devil:
dailydriver
11-28-2005, 04:39 PM
:funny:
VictorT
11-28-2005, 05:13 PM
Sounds like this is something you do a lot, so it might be time for a full on brake upgrade. You have lots of options... Just let me know, and I can explain more...
00 Trans Ram
11-28-2005, 07:31 PM
Guys, I don't know - I've got Hawk HP+ pads, stock rotors, and even I have gas buildup under braking sometimes.
Of course, the gas may have something to do with the all-you-can-eat mexican buffet down the road that I frequent. Hmmmm - I need more research. :jest:
mitchntx
11-28-2005, 07:36 PM
The ultimate bang for the buck brake upgrade ...
http://frrax.com/rrforum/index.php?act=ST&f=13&t=6136&s=
4 piston Brembos and a 13" rotor ... ever seen a F-car do a stoppie?
I had these brakes on my street car, which saw back to back to back 120+ to 50mph stops on several road racing courses near me and I never had an issue during a 30 minute pounding lap after lap ...
