will this cam work for me?
Old 11-14-2005, 11:17 PM
spec_j's Avatar
Default will this cam work for me?
226/229/113 582/590 comp cartech stage 3 cam
i have a 4k stall, stock 3.23 gears, stock intake
EDIT: if possible, does anyone have the specs on this cam? or dyno graph?
Old 11-14-2005, 11:29 PM
CaptUSA's Avatar
Depends on your goals.
Will it work for you.....??? Well, it'll run, if that's what you want to know.
It will idle moderately rough, and is small enough that your stall and gears should be okay. Longer exhaust duration will be good for forced induction.
Other than that... Just have to do your homework. (or at the very least tell us what you want to end up with)
Old 11-14-2005, 11:48 PM
spec_j's Avatar
well my goals are to have it 11.5's give/take, i just wanna know if it wil keep me in the RPM band of my car b/c i have a 4k stall
Old 11-15-2005, 05:53 AM
s346k's Avatar
if you want 11.5 or quicker, you'll need a bigger cam. the 4k stall provides nice shift extension...get a bigger cam.
Old 11-15-2005, 09:47 AM
seadoo's Avatar
well, s346k... not really true... its all about combo. the goal is to have about max trq from 4K and up a few hundred, then make the max power from the 5300-5900 range (shift ext.)
and spec, the cam is going to run its best w/ an ls6 intake, ported TB, and a pulley... remember,you got hook ups
Old 11-15-2005, 01:15 PM
spec_j's Avatar
yeah the right combo is a must. Hey seadoo took you long enough to reply, but yeah im going to get a pulley/ported TB hopefully around christmas time. as for hte intake, still searching. I just want to know if this cam will do what im looking for, IE: stay in my shift extension. b/c if it doesnt, then its not worth getting.
