Need LS1 PCM on LS2 engine
Old 11-15-2005, 10:32 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Default Need LS1 PCM on LS2 engine
Anyone know if an LS1 PCM will run an LS2 engine. This is for a twin turbo sandrail customer of ours. It just strictly needs to run the engine and if possible use HP tuner 2 bar map option to see boost. Is this possible??
JZ
Old 11-15-2005, 11:11 AM
horist's Avatar
Definetly possible to run an LS2 w/an LS1 PCM (note only a 2005 LS2, 2005 = 24 tooth reluctor wheel, 2006 = 58 tooth reluctor wheel)
However, I'm not sure if people have gotten past the issue w/knock sensors (or rather how they got past it) ... May want to post up or check the LS2 section... but people have definetly done it
Old 11-15-2005, 11:15 AM
Dixit's Avatar
Well the knock sensor part is just using the LS2 knock sensors and use the extended wires that say like SDPC sells with their blocks. Its plug and play with the LS1 connectors for the knock sensors.
Old 11-15-2005, 12:09 PM
Brains's Avatar
Buddy of mine is driving around with an LS2 stroker in his 2002 Z/28
