twin turbo sbc
twin 70's on a 350 tpi? correct me if i'm wrong, but wont that take forever to spool up??? i'm just curious why you decided to go with that size turbo's, not knowing the rest of your combo of course. what kind of power #'s are you looking at making? looks good anyway!
i dont think it will be that bad its only a .68 a/r plus the motors is going to have a a custom grind cam 8.5 comp. and ported fastburn heads
yea, i know it's not a factory style tps intake, but like he said, it's kinda like it. well, give it a shot. i'm sure it will make power either way!!!
Originally Posted by ProStreetZ28
That TPIS intake should work real good for what he's doing, the short runners on it work great up to around 6500RPM (more with port work), they just don't offer a bunch down low the way a stock TPI does. With a small a/r on the turbines it should spool up OK, but they are the big side for that application. In the picture it looks like the headers were setup for a T3, I'm assuming that your swapping that out for a T4 flange. With the Fast Burn heads it should make some power. Are you going to be driving it on the street? If so think real hard about the 8.5 compression, with it down that low it might be tuff to drive on the street. In the past we've had problems with boosted cars loading up and not driving well on the street.
the .68 i think will spool fine
by the way im trying to make it to 1000hp or as close to it as i can on pump gas so i kinda need 8.5-1 compression
