Clutch or Tranny
Clutch or Tranny
I have a 98 6spd SS.
Problems:
When i'm WOT, It hesitates before I can shift it into 2nd from 1st
If I put the clutch in and rev it, then put it back in gear it grinds
When WOT, it grinds even with clutch all the way in when shifting into 3rd or 4th
Randomly locks out of gears
The stick sometimes violently shakes when cruising in 4th gear
What needs a 'fixin?
Problems:
sounds like you need new sycnro kit. could be that your hydos are not bleed properly also, but usually its just hard to shift under WOT not grinding. dont know what to tell you about the shifter shakeing. could be the trans mount. does it only do it in 4th or 5th and 6th also when crusin?
