98 ls1 hptuners accel enrichment?
Old 11-16-2005, 12:34 PM
ls1mx5's Avatar
Default 98 ls1 hptuners accel enrichment?
Hey Guys-
We have been tuning my car in SD mode with hptuners 1.7, but can not get to any of the tables for ACCEL Enrichments. Does anyone know why? Engine and ECU are 98 camaro parts, cam is 02 ls6.
thanks
karl
Old 11-16-2005, 12:38 PM
LS1TECH Sponsor
Magnus's Avatar
Accell Enrich are V6 parameters. You'll see that section populated if you open up a V6 file.
Old 11-16-2005, 02:11 PM
ls1mx5's Avatar
ok, so they will not help me tune my car... is everything done with power enrichment functions instead? right now WOT causes a big lean spot from 2k-3k, then it smooths out, stops sputtering and pulls hard...
thanks
Karl
Old 11-16-2005, 04:45 PM
MECHAM's Avatar
whoa...you are running your 1998 Camaro with a 1998 LS1 ecu in SD mode?
Old 11-16-2005, 06:12 PM
SmokingWS6's Avatar
There's nothing wrong with that at all. I run sd from time to time.
Anyway, if you have a lean spot, the two tables to adjust are PE(power enrichment) or VE. Look at the PE table from 2 to 3k rpm and bump up the fuel accordingly.
Old 11-16-2005, 07:31 PM
ls1mx5's Avatar
Mecham- no, not a 98 camaro, i am running my 1990 miata with a 98 ls1 and 98 ls1 ecu, and an 02 ls6 cam in SD! ;-)
Smokingws6- Thanks, I will look into the PE tables further!
The car still seems way down on power... Almost like timing is being pulled. From searches, people mention that the 98's have overly sensitive knock sensors, if this is true, how do I turn the sensitivity down or off? The car has custom headers, and intake piping... Thanks for the help!
Karl
Quick Reply: 98 ls1 hptuners accel enrichment?
