Is my Mass Air Flow Sensor bad
I have a code that popped up right after I ported the Throttle body. the code is either p0103 or po130 (can't remember) either way the code says Mass Air Flow High input. I don't know exactly what this means, but the dealership says that it is either a dirty mass airflow sensor or a bad maf. I cleaned the sensor with rubbing alcohol and the light is still coming on. Wondering what everyone thinks about this. If it is bad is the slp 85mm a good upgrade.
yeah, thats a code for a bad maf as far as i know. I haven't heard much about the slp 85... definetly do your research... just realize though, that the maf isn't really needed for the car to run well... Our cars actually run very well in SD mode.
