4L60E Housing Problems
Was just wondering whether anyone else has had any problems with the tailshaft housing cracking. Mine cracked right in front of the trans. mount. I had it welded, and it cracked again, (I think the welding heated the aluminum up too much). Anyhow, I got a new one coming from GM (for a tune of $200, damn crooks) so it should be fixed soon.
Originally Posted by Yank
drive shaft balance, bad u-joints, poly mount, worn bushings in the transmission,pinion bearing, ponion angle and bent output shaft any of these can all be to blame.
let us know what you find
Well, The new trans tail housing I had bought cracked again about a week ago. I'm thinking that my driveshaft is outta balance...
So I got a housing coming from 11SECSS, and I bought an aluminum D/S. I hope this solves my issue, if not I don't know what I'm going to do...
