RED and BLUE PCM connectors
Old 11-19-2005, 12:41 AM
txoutlaw's Avatar
Default RED and BLUE PCM connectors
I need theRED and BLUE PCM connectors
Other than junkyards where can you get these new? I thought i had a good source and no one (JYs) want to part with them by themselves!
Old 11-19-2005, 01:02 AM
Spenser309's Avatar
hey you can buy them from delphi but only in packs of 65 and at 20 bucks a connector. Preatty insane. Id reccomend the junkyard route.
Old 11-19-2005, 09:56 AM
Brent@LPE's Avatar
dont know but have you tried contacting, www.speartech.com
Old 11-19-2005, 09:28 PM
MEFISTUFF's Avatar
give todd a call @574 267 5554 He has all the GM connectors @ good$
Old 01-18-2008, 12:48 AM
rogerdahlman's Avatar
Default Female Terminals used in Red/Blue connectors
If anyone needs new terminals for their connectors you can get the original Delphi parts from Mouser Electronics. Part number: 829-12084912
http://www.mouser.com/search/Product...mBK4WgOQ%3D%3D
If you order 100 they are only $.22 each. Not a bad deal but it took me several hours to track them down. I have verified they work in both the blue and red connectors.
Roger
Old 01-18-2008, 11:37 AM
01'WS6's Avatar
I think this is what your looking for.
Click Here
Old 01-18-2008, 12:23 PM
wait4me's Avatar
I have about 100 here in stock of used ones. 5 bucks a piece empty 10 with cut wiring on them.
Old 01-18-2008, 08:15 PM
2002_Z28_Six_Speed's Avatar
Click Here
No I ordered one of EFIConnection's blue connectors and it was not the right part. It doesn't fit.
I don't know what it is! Maybe for a transmission computer or more modern, compact form factor???? It isn't Camaro LS1 though
Old 01-19-2008, 09:10 AM
slow's Avatar
can you put it next to a ruler, that looks correct, it is just the blue retainer (which you need 2 of) , but you still need the larger metal piece as well.
I've ordered about 10 from them, and they've worked fine on the harnesses i've made, maybe they sent the wrong one, if my statement above isn't the case.
Ryan
Old 01-19-2008, 10:00 AM
Ryan
Maybe I got sent the wrong one then. I clicked on LSX. The picture abouve. It is 3 inches long. No idea what it is.
Old 01-19-2008, 01:46 PM
kbracing96's Avatar
It looks like the right one to me too. You do realize like slow said you DO need 2 of them for one connector right?
Old 01-19-2008, 06:02 PM
Lextech's Avatar
You don't necessarily need the correct color for them to work. The different colors denote its indexing tab. Different colors have their indexing tabs in different spots. You can trim off the incorrect color connectors indexing tabs and then put a dab of paint on the connector to denote its color/position to the PCM. I have found a lot of Red and Green connectors from Buicks for some reason at the U-Pull junkyard.
Jeff
Old 01-19-2008, 08:24 PM
I will check that out tonight or tommorow and confirm this. Thank you!!
Quick Reply: RED and BLUE PCM connectors
