Generation IV Internal Engine - LS2 402 RX7 tuning help
Mas280
11-19-2005, 05:35 PM
I drove my ls2 402 rx7 for the 1st time today. This thing has alot of TQ. The only problem I am having is that I get knock over 5,000. I have turned the timming down to 25 deg but I still have the problem. Does anyone have a program that would work for my combo. I need one that is from a 01 f-body ecu so i can load it using ls1edit.
402
Ported TEA 5.3 heads
236/236 601/601 115 cam
ls6 MAF that was calibrated but it is still off.
fast 90mm
30lb svo
I am looking for a program that would be close until I take it to the dyno in 2 weeks. I plan on going with speed density on the dyno. Thanks for any help.
Some pics
http://x12.putfile.com/11/32216070070.jpg
http://x12.putfile.com/11/32216061613.jpg
http://x2.putfile.com/11/31512595144.jpg
Phoenix 5.7
11-19-2005, 11:18 PM
do you know what kind of power you are makin? and are you possibly maxing out the injectors and makin it run lean. i know ppl with 402s that would completely max out those injectors
69firebird
11-19-2005, 11:26 PM
thats a nice conversion, whats it sound like with that muffler on it??
Mas280
11-20-2005, 06:25 PM
Phoenix57 I am hoping for something close to 500rwhp. I think that the 30lb ford injectors should be ok. If I need to I will install some larger injectors.
Thanks
Mike
Nate_Taufer
11-21-2005, 11:34 PM
I would try adding fuel above 5 grand and see if your problem goes away.
Nickn20
11-21-2005, 11:49 PM
Mike, you need bigger injectors! bring me the computer I will set you up with a driving program, I can also do the SD stuff now too, you know that right?
RedHardSupra
11-22-2005, 12:01 AM
Hey, I'd love to tune this thing for you, are you using a fbody computer for it?
Nickn20
11-22-2005, 12:23 AM
hopefully he doesnt plan on cheating on me, since I did the two cars in his sig :) yes its a F-body computer BTW.
forgot to mention 500 rwhp will be a maxed 30 lb injector 42s the duty cycle will be around 70ish% which is perfect, room to grow, etc.
Mas280
11-22-2005, 12:36 AM
Nick Thanks for the dyno time on the last motor's. i did not know that you where doing SD tune, that is good news. I ordered some 42# imjectors, I think that I am going to put on some ETP 225 heads before I dyno it.
Thanks for all the info.
Mike
Nickn20
12-01-2005, 01:59 AM
Man, did I call this one or what Mike?
For the people who weren't there I tuned the car tonight, IPW was right at 70-71% peak horsepower at 12.5 AFR.......
Mas280
12-01-2005, 02:01 AM
Thanks Nic for the tune, can you email me the dyno sheet so I can post?
489RWHP
464RWTq
Nickn20
12-01-2005, 03:42 AM
Mike I cant pm you back for some reason its messed up, I emailed the files twice, here I just hosted it on my site.....
http://home.comcast.net/~nickn20/MikeRX7/MikeRX7ba.jpg
I have more fix your PMs and I will email them again or send you links....
LS2 V8 Miata
12-01-2005, 10:03 AM
What PCM and who's wiring harness? Fly by wire, OEM 90 MM Throttle body or cable (FAST or something) stock MAF sensor?
What tuning software?
Please help a fellow Bowtie / Mazda freak!!!
Really impressive numbers!!!!!!!
Drewman
12-01-2005, 04:39 PM
Awesome curves Mike. Get those new heads on it and see what it puts down. :cool:
Mas280
12-01-2005, 08:53 PM
LS2 V8 Miata, I am using a 2001 f-body ecu and harness.
90mm Fast intake and TB
Nick used HP tuner on the car and tuned it in SD mode.
Today I put on a 4" intake and made 489rwhp 477rwtq
With the old 3.5" intake I was only making 463rwhp 444RWTQ
So the 4" intake was worth 26RWHP 33RWTQ
Right now I am doing a 2005 gto ls2 into a 280z, it will DBW using the stock TB. I will also be using the stock gto computer.
Drewman, I hope I can make a few more HP with the ETP heads.
LS1SpeedAddict
12-01-2005, 09:20 PM
Id like to hear how it sounds with that muffler
77ZETA
12-04-2005, 08:32 PM
Here is a video of it!
http://videos.streetfire.net/player.aspx?fileid=35C778C6-110F-419C-8372-576E04C5E2C4
ZL1camaro
12-04-2005, 08:54 PM
lllove the setup ... how much do rx7's weigh?
NoGamesLS1
12-04-2005, 10:19 PM
Hey you just got too much testosterone in that car :burn: haha Thats a kickass conversion
