Generation IV Internal Engine - Whats a "round-about" price to stroke my ls2
caindo
11-19-2005, 06:24 PM
Gauging prices so I don't get gouged if it comes to this.
05 gto
pull motor
stroke it to 402
eagle crank
mahle pistons/rods
install motor
tune.
any "around" prices I'm looking for?
Beast96Z
11-19-2005, 06:38 PM
Assuming most 402's cost about $4k, you shold be able to come out around $3k if you turn your block back in as a core. This is for the short block only. The tune will run about $500. Motor installation is will be the biggest "who knows". Every shop charges something diffrent. Then you have all the other parts like heads, cam, headers, exaust and so forth.
caindo
11-19-2005, 06:44 PM
i just want to stroke my motor and use all my parts, maybe toss in a cam. this is a budget rebuild in-case that sound it made today was a bearing being spun.
Doomsday
11-20-2005, 01:00 AM
Budget? :buttkick: Its a sickness, its never ends. To get an idea of prices for labor and time go to moreperformanceinc.com under the service link. Somewhere there you will find rates on types of installs. Goodluck staying with in your budget. :jest:
We can use your block and build you an engine using your stock crankshaft. Removal of the engine, rebuilding it including using Callies Compstar rods, Diamond pistons, Comp cam and Comp timing chain. New oil pump, reinstalling your heads and reinstalling the engine and chassis dyno tuning it is $4,500.00 total. The stock crank is good for 900 to 1000 hp.
Adding a Callies Compstar stroker crankshaft for adding cubic inches would be extra. I'm not sure of the crank cost, I have it at the shop.
Adding upgraded heads would only cost you the amount that the heads are. Patriot Stage 2 heads are only $1,100.00.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
