BMN question!?!?
BMN question!?!?
I was just outside checking my window switch to see if the lights were lighting up correctly. Ok when i start the car the red light comes on. When i get into my turn-on rpm the green light comes on. When i get to the turn-off rpm the green light is still on. How do i know it is shutting off the nitrous at the right rpm. I have a dyno appointment monday where i'm going to spray for the first time and i don't want him to be spraying off the rev limiter, so i want to make sure that the window switch is shutting off the nitrous. Is there anyway of testing besides physically doing spraying it?
I had probelms with my BMN switch. I knew there was a problem when I did not feel the kick at the track. My suspicions were confirmed at the dyno. I switched over to an MSD switch. Others have had good results with the BMN switch. Sorry, but I think you are only going to be able to test it on the dyno. Good Luck
