Sponsored by: DashLynx
cobra shift knob
Old 11-19-2005, 09:50 PM
ls2 bait's Avatar
Default cobra shift ****
ive seen a few of u have installed them...what does it take to do this? will it just twist on???
Old 11-19-2005, 10:04 PM
ls2 bait's Avatar
btw i just noticed thru search that some people have just put a cobra shift handle on, anyone have any pics of this? i like how my fbod one is angled towards me-im short.
Old 11-19-2005, 11:57 PM
DamanSS's Avatar
I tapped out the cobra **** and just twisted it on so tight it aint commin off
Old 11-20-2005, 12:08 AM
DVST8OR's Avatar
Here is a little write-up I did for this mod
https://ls1tech.com/forums/appearance-detailing/246893-cobra-shift-knob-questions-answered.html
Old 11-20-2005, 10:33 AM
ZEEMAN's Avatar
Prob be real easy to just get a 5.0 short stick
Old 11-20-2005, 11:21 AM
jinxedz's Avatar
I just tapped out the Cobra **** and screwed it on my 5.0 short stick.
Filled it in with some hot glue as well... keep rattles down and such.
Old 11-20-2005, 12:33 PM
Black Z/28's Avatar
https://ls1tech.com/forums/showthread.php?t=246893
Your write-up said there were only 2 options. If you added the third option your write-up would be complete.
I re-tapped my Cobra ****. This may not be the best option for some because you need the right tap & drill bit but it does allow you to continue using Camaro shift ***** if you decide to change it out again.
Old 11-20-2005, 02:06 PM
FAST LS1's Avatar
I drilled and tapped the Cobra shift **** also. It does take some equipment, 2 drill bits, the special M16x1.5 tap, and preferably a drill press. Other than that it was much easier I thought than changing the shifter stalk.
Old 11-20-2005, 02:35 PM
DamanSS's Avatar
I will say, it is the sweetest ****, i couldnt be happier (its the only thing ford did right, jk)
Old 11-20-2005, 11:21 PM
Cornfed's Avatar
J/K
It has looked nice in his car for over 2 years.
Old 11-21-2005, 03:44 AM
Black Z/28's Avatar
The Cobra **** is cool!: (carbon fiber version)
