what brake fluid do you guys use in your hydrolics?
im just wondering what everyone uses becasue i went to the tack yesterday and car was launchin sick but i could not get into second because the clutch fluid is all black and burnt
what fluid do you guys use in high performance aps that wond mess up the seals or anything
thanks guys
joe
thanks guys
joe
is the Motul 600 like a regular dot 4 fluid or is it something completly different
can it be mixed with other stuff?
do i ahve to start off with a completly dry system first?
thanks
joe
thanks
joe
Originally Posted by Samba242
Valvoline synthetic DOT4
i actually just bleed my system and used Valvoline synthetic DOT4 because i had an unopened big bottle in my garadge and i needed to get that black **** out of my master and lines
everything is clear now for the most part and i also mityvaced it but got very little air out car is shiftin good now but the test is the strip
i will put a new slave in next time i do a clutch
then i will put some motal in probably
