What takes more power to turn?
Old 11-20-2005, 04:32 PM
JEB99TA's Avatar
Default What takes more power to turn?
1. Stock 10-bolt 28 spline axles/rearend asembly
or
2. Strange 12-bolt 33-spline axles/rearend asembly
Old 11-20-2005, 07:46 PM
chicane's Avatar
Well, if it were actually a measurable difference that accounted for something.....
The 12 bolt has a larger ring gear diameter (and associated parts) which would increase the rotational inerita.
But, both the 10 and the 12 bolt are on the same pinion centerlines, so the difference would only be in the difference in rotational diameter and nothing is lost like it is with the 9" due to it being so much further off the ring gear centerline. That is where the power and inefficiency is the most apparent.
Old 11-21-2005, 06:33 PM
JEB99TA's Avatar
Nice explanation ... thanks a lot chicane.
Old 11-21-2005, 07:27 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
12 BOLT!!!! everything is bigger and heavier.....
Old 11-22-2005, 04:49 AM
JEB99TA's Avatar
What about when you add relocation brackets? I know by adding them you change the pinion angle, but, with a 12-bolt and MT ET street radials, would it even be beneficial to add them ... or a waste of time?
Old 11-22-2005, 01:05 PM
Moderator
jimmyblue's Avatar
They're talking pinion relative to ring gear, no diff
I've seen puts the pinion dead center so you have
helical gears that scrub a little as they turn, and
the more off-center, the more scrub. External pinion
angle doesn't affect this internal geometry.
I figure a big gear deeper in thick oil is going to apply
more fluid drag.
But the power lost in a busted mini-10-bolt can be
substantial
