stock 5.3 heads whats next...
Sorry if I am asking the wrong question but what do I have to do to some stock 5.3 heads to get them to work with my cam. (224/224/581/581)
I know that i am going to have to change the springs, port and polish but what else... Valves?? if yall have part numbers to the parts I'll need that will help too.
thanks
thanks
If you want to get out cheap, you could upgrade to stock F-body valves, but a upgrade to some 2.02/1.57 valves would be good. TEA has great luck with a 2.02 intake and a stock 1.55 valve. Other than that and the stuff you mentioned, just make sure there flat and you should be good.
