Mmmmm MMMmmmmm moving along
Making some more progress, found out that 2 of the fuel lines for the direct port won't work so I need to make some replacements, got the heads torqued down. All we're waiting on now....
1) Jesel J2k Rockers From ETP
2) Custom Pushrods from Comp
3) Vacuum Pumps from A @ A Corvettes
4) Finish up the fuel system
5) Modify vararam to a 4" outlet
Thanks guys! This ain't as high dollar as it looks. As far as the fuel system....
Main system:
Racetronix Intank Pump with Harness
KB Boost a Pump
97 Rail and return lines
Supplement system:
Custom aluminum Fuel Cell
Walbro 255lbs pump
-6 lines
Mallory Regulator
Aeroquip lines and fittings
40psi
Main system:
KB Boost a Pump
Supplement system:
Walbro 255lbs pump
-6 lines
Mallory Regulator
40psi
