question on hydrolics
Old 11-20-2005, 09:55 PM
Slow00ls1T/a's Avatar
Default question on hydrolics
Ok I recently checked the clutch fluid and it was black so my friend told me that since it was black that i needed to replace slave and master bc as soon as i replace the fluid it will go black after only a hundred miles is this true.thanks
Old 11-20-2005, 10:03 PM
HavATampa's Avatar
He's 1/2 right. It will turn black again shortly but you don't need to replace the slave and master because of it. There is such a small quanity of fluid in the system and it doesn't take much to heat it up or contaminate it.
Old 11-20-2005, 10:11 PM
i didnt think so but replacing the fluid will help the shifts correct bc it has a hard time gettin into 3rd and i have been readin that the fluid needs to be changed
Old 11-20-2005, 10:49 PM
MrEddie's Avatar
If you haven't done it, you might as well do the drill mod since you'll be replacing the fluid anyway. Also, go get a mityvac ($35 or so but oh so helpful) to remove the air from the system.
Quick Reply: question on hydrolics
