Will 3:73's blow drag radials off the line?
What is your tranny? I am asuming automatic since you went with the 3.73.
When I had stock gears I blew my drag radials off the line. When I went to the converter I blew the tires off, now I have ET streets and if I am not careful I will spin them off the line too. SOLUTION: Get better tires, learn to launch without spinning (rolling into the throttle and not going WOT at the start of the race)
Pretty much if though.....
Are you on stock 10 bolt?
Like I said, it is all about knowing how to drive it! if YO-EL says he comes out of the hole WOT then I would have to call BS, but you can learn a good way to roll into the tire and cut some nice 1.7s or better.
Originally Posted by YO-EL
426 rwhp 407 tq
I run bfg 275/40/17 dr's
Vig 3200 converter
Vig 3200 converter
