stripped
stripped
i was trying to put in the water temp sender in the location thats right above the starter. its supposed to be a 8mm allen, but the 8mm wasnt working at all. so, now how do i get it out?
yup. 8mm allen. the fitting is brass, and its probably corroded some around the threads since its holding back coolant. and since its never been taken out, and the car is a 99...its stuck pretty good. when it got to the point the allen wasnt working, we tried to use a torx but that didnt work either.
