Drag Racing Tech
cam only ls1 times
Old 11-21-2005, 06:18 PM
LS1_PNYTAMR's Avatar
Default cam only ls1 times
02 z28 with 241' castings and ls6 intake
fms f14 232/234 .600/.600 114lsa
fuddle 4000/2.5 converter
4.10 gears
et streets
headers dumped
Lca's
relo brackets
rebuilt trans.. racing clutches ect...
car should wiegh around 3225 with me and 1/2 tank of gas....
and i go to get in dynotuned in 2 weeks... when i run weather should be really cool... b/t 40 and 45 degrees at a good hooking track, d/a should be 0- -1000 ish or less i would imagine.. car ran 12.80 with lid and cutout at 3580lbs otherwise bone stock
what kinda times should i hope for 1/8th and 1/4
i would like to see sub 11.50 1/4 mile times or i guess a low 7 1/8th
if you dont see that happening what other mods should i get?
Old 11-21-2005, 06:30 PM
eric01ss's Avatar
remove weight and that should help
Old 11-21-2005, 06:43 PM
rufretic's Avatar
At 3225 he already has lost some weight. I have a very close set-up(F14 112lsa, SS4000,3.73s,bolt-ons,susspension) but I'm closer to 3500lbs or more and I ran a 11.9 with traction problems. I had bfg drag radials and could not get it to hook. The 11.9 was with the tcs on. I still pulled 1.6 60s so with traction I think I could pull 1.4-1.5 and that would make your 11.5 goal very possible. Plus it was 80+ and humid when I went.
Old 11-21-2005, 08:28 PM
Shon Herron's Avatar
You will still be slow. Just messing with ya!
Old 11-21-2005, 10:25 PM
you woud be too if you drove ur own ****, ur mod list - the russ mod that is lol
Old 11-21-2005, 11:50 PM
Retired Street Racer
Matt D's Avatar
Should be around 11.2@118mph
Old 11-22-2005, 01:41 AM
yea... im thinking tq arm... skinnies, and another 50lbs somewhere...
at any rate i need to lose a lil more to offset the roll bar i hope ill be forced to get!
Old 11-22-2005, 06:13 AM
You do what it takes to set records.
Old 11-22-2005, 07:38 AM
SlickVert's Avatar
That is good for aleast 11.20
Old 11-22-2005, 11:30 PM
yea everyone ive talked too that has or has had a cam only or good running n/a setup, thinks i can get low 11's... hell without the cam i know guys running high 11s with a 4000 and 4.10s.. but it just seems its not that easy for me
at any rate thanks for the encouragement.. i got some guys thinking ill be stuck around 12.50 or 8.0 in the 1/8th lol...
Old 11-23-2005, 09:52 AM
Bryan @ Speed Inc.'s Avatar
well if you don't reach your goals... go with a bigger cam! lol. i think low 11's w/ good weather and a well prepped track should be no problem.
Old 11-23-2005, 11:32 AM
yea there is always the 150 shot.... i dont think ill ever get rid of that
