Engine going to dyno
Well my engine is finally going to the dyno. Only took 6 months to get built. It is a 385 running on pump gas. Engine builder says it should make just over 600hp. I am going to take a video camera. I will post videos asap.
http://i5.photobucket.com/albums/y19...1979/front.jpg
http://i5.photobucket.com/albums/y19...c1979/back.jpg
Chevy 010 4 bolt main block, Eagle 3.75" cast crank, SRP 4.040" -25cc pistons, Crower 6.0" I-Beam 4340 Rods, Clevite H series bearings, ARP fasteners, Crower custom solid roller cam 282/286 .712 lift, Crower lifters w/ high pressure pin oiling, Chet Herbert 3/8" 4340 pushrods, Dart Iron Eagle Platinum 230cc heads CNC'd by M2 racing (320cfm@.700)(284cfm@.700 out of the box), Jesel Comp series offset shaft rockers, MSD Pro billet dist, MSD 6 digital+, MSD 8.5mm Super conductor wires, Professional Products Hurricane intake manifold, Custom headers yet to be built, and carb size yet to be determined.
M2 made some good improvements on the port flow i see.The cam your using is a 282/286 at .050 lift???if so wow what a big cam.what rocker ratio are u using???
cant wait to see the dyno results
keep us posted
keep us posted
