running 100 octane
Old 11-22-2005, 06:54 PM
bmfcamaro's Avatar
Default running 100 octane
would it be worth it? i live in california next to willow springs raceway. they have 100 octane unleaded gas. to tune for this you just up the timing to pull out more horsepower? any input please
Old 11-22-2005, 10:05 PM
Bombguy99z28's Avatar
No it would not be worth it. Higher octane fuel takes more energy to combust and lowers combustion chamber temperatures. You will always make the most horsepower with the lowest octane fuel you can safely run.
Old 11-22-2005, 10:27 PM
bmfcamaro's Avatar
then why do people make more horsepower with 93 octane. i only have 91.
Old 11-22-2005, 10:37 PM
horist's Avatar
^^^ because they can add more timing ... high compression cars need higher octane because the air charge has a higher likelihood of pre-ignition, so by using a higher octane gas, you delay this
A car running 91 octane may get some knock and the knock learn factor would then lean more towards the low octane timing tables... a car running 93 octane may not generate as much knock so it has a learn factor closer to the higher octane timing tables...
If you could run the car on 87 octane (i'm not suggesting doing this) without detonation and the same timing, in theory you would make more power because the fuel and air charge is easier to ignite
A car that runs fine on 93 octane (meaning it's 100% high octane tables, proper AFR etc...) will likely actually slow down if it runs 100 octane (may not be drastic, but since the air/fuel charge is harder to ignite , the flame front won't begin at the proper time... so instead of beginning at say 28* before TDC, it may not actually begin until 27* TDC (even though you commanded 28* of spark advance)
Old 11-23-2005, 07:05 AM
Dave F's Avatar
I have the ASA/World Challenge spark tables if anyone wants them.
Old 11-23-2005, 08:55 AM
12secSS's Avatar
To back up Mike, I have experimented with 87 octane. For me, to optimize it, my VE table and the timing tables varied some. There was virtually no performance loss on the car. I took it out to the track and it trapped within 1/2 MPH of the 91 octane tune. Also, we experienced no benefit to fuel consumption, but did pay less for fuel (91 Oct. = $3.05/gal vs. 87 Oct. = $2.85/gal). On our race car, we use pump 100. The Z28 has about 11:1 CR and runs on 38 degrees with peak HP and TQ. Although I believe it is not optimized, but it is running on the safe side to prevent detonation. On a stock style engine, I wouldn't recommend this. The most octane would be a blend of 100 and 91 to achieve a 94 mix. Back before I had HPTuners, I tried a lot of different mixes and this (94 octane) would trap the highest MPH on my stock SS.
Old 11-23-2005, 11:35 AM
I run about that same mix... 3:1 91/100, comes out to about 94
I agree, in a stock motor with stock timing 93/94 octane would pretty much insure you wouldn't get any knock and would always be on the high octane timing table. Anything higher would just be a waste. I think with 91 you would not suffer any performance loss or see any performance gain going to a higher octane except when ambient conditions are pushing it (real hot weather or really extreme driving).
Now, start modifying the engine, higher compression, nitrous, boost, your needs will change and you will have to modify your combustion setup appropiately. How you modify that really depends on your specific combo. Trial and error is really the best way. If you bump up the compression you WILL have to play around with timing and octane to figure out what the engine wants. Its a give and take scenario, and in my case since I drive a lot on the street running 100 octane and aggressive timing isn't really a viable option, at least not at the moment. So I run a 94 octane blend and mild timing. I'm giving up a bit, but saving some money. The car can still hang with cars that have dyno'd well over 400 at the wheel, but there is more in it.
So basically, its not what octane do I want to run, its what octane do I NEED to run And does my wallet support my engines appetite.
