438 In A 6.0L
Old 11-24-2005, 09:24 AM
Z240LS1's Avatar
Default 438 In A 6.0L
Hi every 1
I am planning on a 438 Rotating Assembly kit to be used in a 6.0L iron block, but I am not sure if the 6.0L iron block can handle 4.125 bore or not.
- Did any of you tried it or heard about it?
Please let me know.
Chevy 438 LS1 Rotating Assembly kit - 4.100 Stroke - 6.125 Rod - 4.125" Bore.
Old 11-24-2005, 09:28 AM
dame's Avatar
your not going to get that size bore out of the iron block......your gonna have to shell out the money for a resleeved block if you want those cubes (or go c5-r)
Old 11-24-2005, 10:06 AM
383ss's Avatar
search is your friend. this has been beat to death. 4.030 is standard. you can do 4.060 if you have the block thoroughly checked out.
Old 11-25-2005, 01:12 PM
Firehawk441's Avatar
This is true. If you can go .060 with your block, you will end up with 427 cu.in.
Old 11-25-2005, 01:30 PM
cyphur's Avatar
Even then, I wouldn't want to push that too hard on a daily driver. Maybe on a race block only......
Go with a resleeved for that kind of bore.
Old 11-25-2005, 01:54 PM
n2o junkee's Avatar
I know this is a little off topic but does any of you guys know the formula to find how many cubes I will have.
Old 11-26-2005, 12:45 AM
Solid346's Avatar
0.7854 x 8 x bore size x bore size x stroke size
Old 11-26-2005, 06:54 AM
smask04C5's Avatar
CID = bore x bore x stroke x 6.2832
Old 11-27-2005, 11:34 AM
Z240LS1's Avatar
Thanks for your replies.
cyphur_traq,
Can I use 4.125 bore sleeves in a 5.7L aluminum block?
Old 11-27-2005, 11:51 AM
Yes you can resleeve your block.
Old 12-04-2005, 04:11 PM
Gm-LSX's Avatar
Question
Hi
Will a 4.040" overbore work w/o Sonic Check or other Tests?
Search turned out negative (To get the classical T/A 400 Cubes For Action with a short 3.9" Stroke)
(Bore/2)² x Pi x Stroke x Number of Zylinders will also work.
