Sponsored by: DashLynx
Old 05-20-2016, 01:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
Halo Headlight/Smoked Corner Install(w/pics)
Old 11-25-2005, 02:53 AM
Hoss Ghoul's Avatar
Default Halo Headlight/Smoked Corner Install(w/pics)
OK, I did this a few weeks ago but just got the film developed. No real glamour shots, not much in the way of showing off the halo lighting itself, but enough for anyone looking to do this to see whats involved.
Here's the lights, nicely packaged:
Stock light:
Light Removed, I unbolted and removed the bar connecting the light to the frame and moved it out of the way, but once it is unbolted from the light you can -slide- the lights out of their housing:
As many others on this board have mentioned/recommended I unbolted and reused the factory light mounts. They seem a bit sturdier and as you'll see below I do not have the bad gaps that can be a problem with these lights.
CORNER LIGHTS
Easy, just remove the 2 bulbs with a twist, and then unscrew the two bolts on each side, and the one tricky to get at middle bolt coming up from the cars underside.
Here's what it looks like with everything removed:
You can see all three corner light bolt holes in the above picture.
Continued Next Post.
Old 11-25-2005, 03:10 AM
Hoss Ghoul's Avatar
The new stuff now goes in, just reverse your work, lol...
The corner install is easy and straightforward, the kit I bought off Ebay included the new brighter orange colored bulbs. Be careful not to overtighten as I did snap off one bolt while trying to get rid of the "play" the lenses had.
Corners done.
At this point you'll want to know how you are going to wire up your halo lights. There are several methods, just do a search and you'll find some good suggestions/writeups. If you decide to wire them into the foglights you may want to wire them in BEFORE installing the corners as you will have more room to work with.
I installed the halo's into the DRL/Parking lights. I used these: http://www.delcity.net/delcity/servl...id=9329&page=1
to tap into the wires. You can pick them up at any Radio Shack.
The wires are insulated inside of plastic tubing, pull the tubing back and cut into the tape wrapped around the wires. Black is the ground. Brown is the juice. Red and White off of the halo. White is ground, Red is the juice.
You have to be a bit nimble with the fingers, but once you get the wires clamped into the T-Taps(I used super glue and pliers to squeeze them nice and tight/closed) you're good to go. I then tightly wrapped the T-Taps with electrical tape.
Right then, so now comes the fun part. Getting the light back in to the housing. This IS a pain in the ***. You just have to be patient and play with the two adjustment screws. I also recommend removing the little snap-bolts holding the front bumper cover on, then lifting up on it to give you a little more play when trying to fit the light in(also helps with removal).
Old 11-25-2005, 03:15 AM
Hoss Ghoul's Avatar
After you get the lights in adjust their fit to the bumper with the adjusting screws, which also aims the headlight. I was fairly lucky here in that mine fit nicely and after adjusting them for fit and finish I found the lights were still quite well aimed.
Here's a few pics of the finished work:
Old 11-25-2005, 03:16 AM
Hoss Ghoul's Avatar
Old 11-25-2005, 03:57 AM
1SicV8's Avatar
very nice
Old 11-25-2005, 08:21 AM
Durien's Avatar
sweet.... i am going to put mine on in a few weeks
Old 11-25-2005, 10:42 AM
parbreak's Avatar
Very nice looking. Excellent write up and pics too.
Old 11-25-2005, 10:49 AM
Breathtaker's Avatar
Nice!
Old 11-25-2005, 11:12 AM
parbreak's Avatar
Actually I think this thread just convinced me to get a set!!
Old 11-25-2005, 12:18 PM
Roarin_8's Avatar
Take that grill of and you'll be set, it doesn't even look black anymore. I also did the black halos with the black smoked corners.
Old 11-25-2005, 01:44 PM
quiet_storm98's Avatar
its a good thing that you mentioned using the stock brackets..at first i used the ones that came with the lights but with those the fitment was way off and the lights were aiming at the ground and it seemed like no matter how much i tried to adjust them they just weren't right..so finally a few months ago i used the stock brackets and now they fit just fine and are aimed correctly..however they still dont fit perfectly but they still look 100 times better then the stock ones
Old 11-25-2005, 02:44 PM
meissenation's Avatar
VERY nice writeup and pics!
Old 11-25-2005, 03:20 PM
GrahamHill's Avatar
Yes'Sir!
Looks great!
Old 11-25-2005, 06:08 PM
Hoss Ghoul's Avatar
Thanks everyone.
The grille is the next job. I'm planning on a black powdercoated billet grille with a classic Z/28 emblem. Hopefully will have that in my hands and on the car by early-mid Jan.
Old 11-25-2005, 06:58 PM
raginazn616's Avatar
probably a stupid question...but when does that center lens light up? i'm about to get a set and can't figure out whether it comes on with hi beams or low beams or all the time.
Old 11-25-2005, 07:30 PM
Hoss Ghoul's Avatar
You can wire it in multiple ways.
As you can see in my above description I chose to wire the halo into the DRL/Parking lights. By doing this the center(halo) light is on all the time.
Others have wired independent switches, or wired them into their fog lights so they come on with them.
Old 11-25-2005, 08:07 PM
Reject's Avatar
soooo.....wha you doin with the old head lights?
Old 11-26-2005, 06:32 AM
where can i get some of those smoked corners?
Old 11-26-2005, 08:22 AM
weaponZ's Avatar
where did you buy everything and how much?i too have a different opinion on them.
Old 11-26-2005, 08:28 AM
steveo346's Avatar
sell me your old headlights buddy...as long as their in good condition
Quick Reply: Halo Headlight/Smoked Corner Install(w/pics)
