Drag Racing Tech - Skinnies and Meats question....
TNTramair
11-25-2005, 07:55 AM
are there any available that i can run without having to grind the calipers to make em fit?? if so, what size to run.
time to throw on some meats and skinnies and see what this thing is supposed to run down the 1320. id like to see atleast a high 10 if i can keep the rear together for 2-3 runs...:D
Bryan @ Speed Inc.
11-25-2005, 11:36 AM
bogarts will fit without grinding... just go get a $30 grinder from home depot and git'r done. buy some welds and get a 5/16" spacers. it's not that bad if you have the right tool.
ChevyZ28Thunder
11-25-2005, 10:26 PM
Just grind and dont worry about it. I went Telstar's which require the most grinding. The front calpiers did not take much grinding. The backs well...
http://members.cox.net/tbpayne/web1.JPG
If you have the money for Bogarts then by all means buy them.
glennster
11-25-2005, 10:38 PM
convo pros don't require any grinding.
ChevyZ28Thunder
11-25-2005, 11:37 PM
So true. Just like the telstar look myself. And no spacers here.
TNTramair
11-26-2005, 07:28 AM
thanx for the help guys.
weaponZ
11-26-2005, 07:57 AM
i got 15x10 weld prostars and had to gring the rear calipor's so deep i was worried if they would still stay togather.i heard the 15x8's only require a little grinding.i also think i have a 3rd gen. offset,because they stick out alot.we put them on my buddys 3rd gen too compare and they tucked nicely.
00SS4780
11-26-2005, 12:15 PM
Those telstars do look great man! I didn't know if they required grinding or not.
Cheater
11-26-2005, 02:45 PM
it's not half as bad as you think
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
