Underdrive Pulley
Old 11-26-2005, 02:42 AM
1sick'98WS6's Avatar
Default Underdrive Pulley
I was wondering if anyone could tell me if the 150+$ on a U/D pulley is really worth it, can you feel a big difference? what kind of times can it take off your quarter, and what does it do on a dyno
Old 11-26-2005, 02:45 AM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
it will help you acclerate.....i noticed a diff with mine def worth it imo
Old 11-26-2005, 09:08 AM
Kyle C's Avatar
I didn't notice any SOP difference. It does look nicer than the stock piece.
Old 11-26-2005, 09:26 AM
freakynipples69's Avatar
you'll gain about 5-10rwhp from it. I'd get it if you plan on doing a cam swap, or looking to get the most HP out of your car from just bolt ons.
Old 11-26-2005, 11:53 AM
ULTIMATEORANGESS's Avatar
its a cheap mod that works but you wont notice anything major.
worth it imo.
Old 11-26-2005, 12:00 PM
kazfan30's Avatar
Not hi-jackin your thread, but what brands of these underdrive pulleys are you guys using to get the good HP gains? I have also been debating on buying one
Old 11-26-2005, 03:11 PM
Kyle C's Avatar
SLP here. I wouldn't think there would be any difference in gain on 25% U/D regardless of brand. I chose SLP because of the high walls on the pulley, haven't thrown a belt yet.
Old 11-26-2005, 06:47 PM
227Hawk's Avatar
Using ASP, did change w/ other mods so it's hard to say what added what gain.
Old 11-26-2005, 08:52 PM
LS1-450's Avatar
ASP here. I agree with all whom mention getting through the RPM's faster. Can also say that it is lighter than the stock pulley & smaller in diameter. Worth it.
Old 11-26-2005, 10:42 PM
Bearcat Steve's Avatar
It tends not to show up on a dyno, but it is consistantly worth at least 0.10 in the 1320.
Old 11-27-2005, 10:04 PM
thats good thats all i needed im going to get one after the lt headers
Old 11-27-2005, 10:19 PM
BLUE99T/A's Avatar
Powerbond, here. Great and easy mod.
Old 11-27-2005, 10:52 PM
CRL 01 SS's Avatar
I went with the Powerbond underdrive pulley when my cam was installed. The Powerbond is the same pulley that SLP uses, but it's cheaper. The Powerbonds are nicer than the ASP pulleys in my opinion. Underdrive pulleys are usually worth 5-10 rwhp on the dyno, and definately worth the money when you're trying to squeeze every bit of horsepower out of the car.
Old 11-27-2005, 11:53 PM
BackinBlack02SS's Avatar
Don't take me the wrong way, but that doesn't make much sense. If it doesn't show up on a dyno, meaning you don't make any more power, than you won't go any faster. From my experience they are worth 5-10 rwhp and about a tenth and around 1 mph in trap speed. If you have a manual tranny, which has a factory idle of 800 rpm, a 25% underdrive cranky pulley will not effect anything negatively. Now if you have an auto, which has a factory idle of 550 I believe, you may run into charging issues. I say go for it.
SSU's Drunk Typing Whore
Lithium's Avatar
Its worth it.
Old 11-28-2005, 12:31 PM
blazinws6kush's Avatar
I heard that you have to modify the asp pulley to install a cam. Thats why i got the slp.
Old 12-02-2005, 05:58 PM
WILWAXU's Avatar
Not true. Only have to modify the pulley if you go with a double timing chain.
Old 12-02-2005, 06:30 PM
amit's Avatar
asp here..
great mod.. definately noticed the engine revving much faster and its farily easy to do (30 mins)
