do the cam boost the compustion ??
Your question is hard to make out, if your asking if a cam will increase fuel consumption then the answer is yes, meaning your MPG will go down, also the clutch you have has almost nothing to do w/cam selection, your gears are 3.42's though, 3.4 isnt accurate, but im guessing that was a typo
To the creator of the topic, if you posted with a more detail/easier to follow post, it would be easier to answer.
LS1Tech Administrator
Received 1,471 Likes
I just read over it and thought it said consumption, thats weird, yea more specific please
Well I'll answer it this way
Combustion - If you mean, the amount of air/fuel burned than, yes.
Fuel Consumption - Yes, amount depends on Cam/Tune
Compression - Yes refer to 10.5 AWD's post. (edit)
Compression - No
Compression - No
Originally Posted by 10.5AWD
Wrong. Camshaft selection can affect compression. Lobe separation angle can affect cranking compression as well as effective compression which obviously has a net effect on maximum cylinder pressure.
woohoo, got it. That took a while.
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
Originally Posted by 777
Static compression (what most go by) has nothing to do with the camshaft. It's computed by bore, stroke, head gasket thickness, deck height, piston height (dished, domed, flat), and the combustion chamber. Most common way of changing the compression ratio is just adding a different set of heads with a smaller combustion chamber.
https://ls1tech.com/forums/showthread.php?t=111207
Ding Ding Ding we have a winner. Static compression is not affected by cam. The above listed elements affect that. Dynamic compression however is affected by cam choice b/c as the valve opens and closes the dynamic compression of the motor changes and is going to be lower w/ than static, and the bigger the cam generally the lower the dynamic compression...
