timing at shift points
timing is dropping to -10 at shft points and when i first dump it to
the floor it will drop to -8 to -10 is that right, and im running 19
to 26 degrees timing thru the hole rpm range with about 2- 3 kr. thanks
Sounds like Tourque Management is kicking in. What all did you tune with your HP Tuners? Did you try to disable Torque Management with the software? Maybe a paramter did not get turned off?
