t56 questions.
t56 questions.
i bought a 2002 ls1 t56. im going to be mating it with a zz383 crate engine from gm. now and im going to be dropping it into my 92 camaro. now the imput shaft is longer in the ls1 version then the lt1 version. is it posible to swap imput shafts?
http://ddperformance.com/
248-735-6220
give these guys a call, I would bet that they could help you!
248-735-6220
you would have been better off with an lt1 tranny because of all the lt1 stuff would bolt right up like flywheel, any lt1 clutch and the slave is external. with the ls1 T56 you are gonna have to use shims and get an adpter like what was said above. but i understand that you are gonna use what you got. i am the same way.
