what else need with cam install??
i have full bolt-ons minus an underdrive pully. i will be getting a 232/236 cam and need to know what types of springs, lifters, etc. i will also need. money IS an option but not a huge deal. thanks!!
justin
justin
justin
justin
definately get some springs (not sure if you'd need double...don't know the specs of the cam), some hardened pushrods at the very least. Might get a ported oil pump and at least an LS2 timing chain.
Actually you should only need the cam, new valve springs, hardened pushrods, and a LS2 timing chain. Lifters are not necessarily required at all.
Don't forget all of your standard fluids and stuff: Coolant (Dex-Cool), Oil (I get extra oil for the first few hundred miles and then change again), Oil Filter, etc
Good idea/time to replace the oil pump as well (if you want too).
A good tune (not just a squeek by so the car will idle) can run you between $400-$700, in my shopping.
First Cam we paid full price ~$480.
Valve springs ~$150
Pushrods ~$110
LS2 Timing chain ~$35
Gasket kit ~$60
Bolts ~$10
Tuning ~$450
Our new one we went with:
Cam ~$180
Valve Spring Kit (Duals) $260
Ported LS6 Oil Pump $80 (second hand find, no miles)
Gasket kit $60
Tuning ?
You may want to consider the dual spring kits since they are becoming a real bargain when considering everything you get. We got the PRC kit, but I think now the Patriot Performance Gold kit is a little better deal (since you get the Super 7 locks)... Although with the PRC's we just went and got some extra stock locks for insurance.
Don't forget tools if you are doing it yourself. You will need a torque wrench rated to ~250 ft/lbs, a pulley puller, 5/16 dowel rods (to retain the lifters), valve spring tool, and your standard garage tools.
EDIT: I went and bought new ARP bolts, and don't forget an O-ring for the oil pump if you change it out. Also you may want to change the plugs (and wires if that is your kick) while doing the cam since it is a good time to do it.
Valve springs ~$150
Pushrods ~$110
Gasket kit ~$60
Bolts ~$10
Tuning ~$450
Cam ~$180
Gasket kit $60
Tuning ?
definately get springs (can't really tell you what kind b/c i dont know your lift), pushrods, LS2 timing chain, cam install kit (which comes with new gaskets), wooden dowel (do a search on wooden dowels and you will see what i'm talkin about, it will save your *** on the cam swap).....if you need more info on the dowels just pm me! Your oil pump should still be ok....unless you have some extra money and just wanna buy another one. You also might wanna go ahead and get an underdrive pulley if you have the funds....it will be easier to put it on now while you have the stock one off. And get a good tune.....remember...it's all in the tune so don't cheat yourself! Good luck!
ok thanks a lot. so i do need hardened pushrods? some people have been telling me i dont NEED them.
Originally Posted by TRU-2GM
stockers will work, some will leave them stock. If it was me i would replace them with some chromolys. You can get a kit that has the springs/retainters/locks/pushrods from the company you get the cam with most of the time.
Race your car!
cam, springs, retainers, timing chain, pushrods ( LS2 is good, and relativly cheap.. and no hassles of shimming pump because of clearance problems ) all needed gaskets and fluids, new crank pulley bolt and seal, and do the underdrive pulley at the same time.. you already have it off.. perfect time to change it.
That's about all you need hardware wise. A tune is 100% needed, don't let people tell you it isn't. Unless you are going to a stock z06 cam or something like that.. the car could probably deal with that, but anything more, and a tune is needed.
