Ugly looking start-up - What's the cure?
Old 11-28-2005, 08:27 PM
Ragtop 99's Avatar
Default Ugly looking start-up - What's the cure?
My O2s go from real lean for 13 seconds to very rich for 25 seconds. During this whole time, it is adding lots of STIT (over 2 add some points). Then the O2s start to cycle a bit and all of a sudden the STIT starts falling fast. By the 1 minute mark, the STIT is .5 negative. By 176* it is telling me that it only wants 6.7 g/sec airflow which seems low.
mods: heads, 228/224 113 cam, 1 7/8" headers, FAST 90mm TB
I've reduced proportional fuel at idle and used the effective area to 48%. Car drives much better since those changes, but cold start up is much worse.
HPT log attached
TIA
File Type: zip
Old 11-28-2005, 09:05 PM
LS1 Tech Administrator
Patrick G's Avatar
Joel, you probably need to go into Open Loop Fueling table (ECT vs. MAP) and lean it out in the tables that are giving you trouble. I copied an Ausie Table from a Holden that was speed density tuned. My open loop startups are much less stinky and a lot more smooth.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-28-2005, 09:52 PM
Ragtop 99's Avatar
I've done that in cold start-up area (MAP 45 - 60, 68* and below) where the multiplier gets real high, but haven't touched the warmer areas. This was a warm start-up since the ECT was about 100*. I also reduced the cranking VE by 8% since it was so much higher than my normal VE (which was reduced by double digits in that range). I also reduced the length of Afterstart Enrichment delay in the 68* - 133* range to lean out the start-up idle. Maybe the combination of the cranking adjustment & afterstart are too much and I've overly leaned it out?
Old 11-29-2005, 02:11 AM
kindaslo's Avatar
Where are your idle airflow tables?
Old 11-29-2005, 05:36 AM
Ragtop 99's Avatar
temp...RAF
32.....16.5
68.....13.5
104....11.7
140....10.8
176....8.5
212....7.5
I have raised them up a bit, maybe they should be lowered.
The car is an M6 with an Al. flywheel
The car is just really stumbling during start-up. Before the IAC effective area change, the car would fire up very nicely.
Old 11-29-2005, 08:18 AM
Patrick G's Avatar
I think changing the IAC effective area to 48% was a mistake. The IAC needs to be a lot more aggressive than that. Basically, when running a 90mm TB, you still want your curve to be fairly steep at first (to handle cold starts and a/c), but then flattening out more once you get past 100 count. I built my own table and it works well with the Nick Williams 90mm TB. If you're running a FAST or TPIS TB, you may need a different curve, but trust me, it will be closer to the stock table than it will 48% of it.
Old 11-29-2005, 10:32 AM
Ragtop 99's Avatar
Patrick :
I tried 60% and that seems to work, but after reading Phil's post about the FAST 90mm TB, I went to 48%. I can put it back to 60% as the car still drove much better than stock.
What do you do to build the IAC table?
Old 11-29-2005, 01:26 PM
Patrick G's Avatar
Basically, I logged my IAC counts and compared them to the relationship between my desired IAC airflow and my dynamic (calculated) airflow. I made sure that desired airflow and dynamic airflow matched at all temps regardless of whether the a/c was on or not. Here's what my table looks like:
IAC Effective area (IAC Steps)
Square mm, Value
0.0 0
2.0 0
4.0 0
6.0 0
8.0 0.000000
10.0 0.000000
12.0 0.000000
14.0 0.000000
16.0 0.000000
18.0 0.000000
20.0 0.000000
22.0 0.000000
24.0 0.000000
26.0 0.000000
28.0 1.000000
30.0 15.000000
32.0 25.000000
34.0 50.000000
36.0 70.000000
38.0 90.000000
40.0 110.000000
42.0 125.000000
44.0 135.000000
46.0 140.000000
48.0 145.000000
50.0 150.000000
52.0 153.000000
54.0 156.000000
56.0 157.000000
58.0 158.000000
60.0 159.000000
62.0 161.000000
64.0 162.000000
66.0 163.000000
68.0 165.000000
70.0 167.000000
72.0 170.000000
74.0 173.000000
76.0 175.000000
78.0 178.000000
80.0 180.000000
82.0 181.000000
84.0 183.000000
86.0 183.000000
88.0 185.000000
90.0 187.000000
92.0 190.000000
94.0 194.000000
96.0 199.000000
98.0 205.000000
100.0 210.000000
102.0 215.000000
104.0 220.000000
106.0 227.000000
108.0 232.000000
110.0 238.000000
112.0 245.000000
114.0 252.000000
116.0 260.000000
118.0 264.000000
120.0 267.000000
Sorry for the vertical format. It's an EFI Live thing.
__________________
Old 11-29-2005, 03:35 PM
Bink's Avatar
HPT log attached
TIA
I'd reduce the Cranking VE by the same % diff between your stock and New VE table. Helped mine alot...especially hot starts. I'm Open Loop/SD. FWIW.
Old 11-29-2005, 10:09 PM
WS6FirebirdTA00's Avatar
i had troubles starting, i changed a LOT!
start up enrichemnt
friction airflow
olfa
spark correction
cranking ve
effective area
idle airflow
those are the main thing i had to do to get it inline. you using hp tuners? if so send me your tune to budchevy358@yahoo.com and i can try to give you a hand. i fougth this for the longest time and this is the best solution i have. i dont know anyone else that had troulbes like i did but i went through a lot to set it up right so it woudl actually start lol. starts strong now and the high idle goes out a lot quicker. i like the way it fires up now
Quick Reply: Ugly looking start-up - What's the cure?
