What Cam CAn i use?
Old 11-29-2005, 07:52 AM
DSRCAM's Avatar
Cool What Cam CAn i use?
YEa i own a 98 ls1 Camaro, does anyone know what the biggest cam i can use but i dont want to change out the valve springs and torque Converter
Old 11-29-2005, 08:03 AM
PREDATOR-Z's Avatar
You allready have it.
Old 11-29-2005, 08:12 AM
prostock_bigblock's Avatar
Ummm , well i see predator gave u a good answer here .
you can go with any cam but that depends on the usage of the vehicle whether it as a daily use , street strip or a drag car , anyways its recommanded to change the vavle springs , push rods ...etc and also TQ converter in order to function in the right way and get every bit oh hp out of your motor.
The last advise I can give you is SEARCH SEARCH and SEARCH .
Old 11-29-2005, 08:22 AM
DSRCAM's Avatar
what cam would u recommend for a daily driver but also street racer?
Old 11-29-2005, 08:27 AM
gccasper04's Avatar
man.. thats a never ending question around here... like the above guy said, best thing to do is search... there is 10000000 topics on it...
Old 11-29-2005, 09:59 AM
PREDATOR-Z's Avatar
First do bolt ons before you think cam.
And in an auto, change to higher stall, you'll benefit more than just any cam swap without supporting mods.
VIG 3200/TCI 3500/ Yank 3500 will get you at least .5 time reductions if you hook
Old 11-29-2005, 10:26 AM
DSRCAM's Avatar
do u think that a 2400 stall is good or thats to little?
Old 11-29-2005, 10:28 AM
PREDATOR-Z's Avatar
Never go less than a true 3500 stall, you'll end up going bigger.
Old 11-29-2005, 10:44 AM
DSRCAM's Avatar
will that stall 3500 be to much if im still running on a bone stock ls1 z28 camaro
Old 11-29-2005, 12:45 PM
I will advise you as predator mentioned to go bolt-ons, and when ever you get your cam choice . throw your matched stall with it , thats better than changing the stall again and again while you swap your cam.
PM if you need any help.....
Old 11-29-2005, 06:30 PM
waterbug1999's Avatar
It will be fine.. You will like the car ALOT more then you do now with just a TC. And after, get some headers, then I would look at a cam. Just my .02
