tr227 reverse split cam with blower
Who said that is a good SC cam? With a SC you need more duration on the exhaust side since your are forcing air in the intake side. So if you want to keep 224 int then go with 228 exh at the least. I would think a cam like that would restrict the engine ability to make top end power and peak early on a blower car. Just a guess.
Originally Posted by boosted99camaro
cam specs are 227/224 .569/.563 114lsa
a good cam for a procharger.
just curious if the reverse split will have an affect on boost?
Andrew
Originally Posted by Ed Blown Vert
It will work, but a traditional split will work better.
