ARP bolts or studs?
ARP bolts or studs?
Iam about to order either bolts or studs for my head swap, whats the difference in installation, torque specs, sequence, and etc? Its a 02 SS with a Phamspeed running 4.5lbs now, and later going to about 10lbs. Its my first time taking the heads off so which would be better, what are the main differrences betwwen them. thanks again
I went through the same research, go with the studs. Many reasons, dont have to clean holes again, will keep gasket in place when installing head. Have heard in some cases were the bolts were a bit to long or there was a problem with the block and full torque was not obtained and head did not seal.
Cant go wrong with studs.
TT-TECH Veteran
The main differences is studs provide a more even clamping force they have better more consistent tq capabilities. The bolts are just as strong, but because you are screwing them into the block if one hole is harder than another it maynot be tq'd as well or the same as the next one that turns easier etc... Tq specs from ARP are 65 on all the large ones and 22 on the small ones. The sequence is the same as the factory. I hope I explainded it good enought for everyone to understand a little better.
only downside is you cant take the heads off with the motor in the car after studs are installed.but studs are better!
"Bolts are specified by Accountants."
"Studs are specified by Engineers."
- Carrol Smith, "Engineer to Win"
Clean the studs well before you use them. Follow ARP's instructions. Make sure you seal the studs that enter the coolant jacket. I recommend more thread sealant than you would normally put on.
You can see some of the head studs in my sig.
Jim
Jim
Restricted User
I will be using the studs over my new bolts, for the reasons stated above. Install is silly, lube with ARP lube and screw in finger tight. That seems easy enough. I was worried about in car removal, but if push comes to shove, then I could do as mentioned and simply unscrew them. Good luck with your choice.
The newer ARP head studs have a provision to use an allen wrench to back them back out, which has already been mentioned. You won't need to do this though to remove the heads on an F Body, as you can still remove the heads with the studs installed, as has also been mentioned.
We always use the ARP head studs in our engine builds, as they do indeed provide a better all around clamping force. Most of our engine builds are for forced induction use, and we feel the studs are the only way for us to go. Bob
maybe i misunderstood about that....but if the studs are still installed how can you lift the head off without hitting the lip where the windshield wipers are?i remember doing a head swap when i just had regular bolts and the far rear center bolt on the passenger side was a real bear to get out and those were factory.
