help!! what heads to go with
hey guys, i was wondering which heads would give me the most power with my cam i plan on running. it will be mti g1 cam. specs are 228/232. 581/574 lift i believe. this will also be with a vig. 3200 stall and 3.73 gears. should i go with mti heads, or afr, or even patriots ls6 heads? i wanna make the most power and make sure i do it right the first time. thanks
thanks for the replies. hey what do you think about prc heads? i emailed texas speed and they said run a 228/228 with their prc heads and a tci stall. what do you think? honestly if i run a mti cam use their heads. but im wondering if theres better heads than mti's. their 2e head is only a ported and polished ls1 head. but i can get stage 2 ls6 heads and cam from patriot for like under 1300 bucks. so im pretty stuck. if i get afr i would definitely have to wait...
