light weight battry? where to get one?
the light weight bettry is a dry cell battry, right?
where can i get one?
for how much?
and for how long it will be active?
and how much weight exactly i can save with one?
thanks.
for how much?
thanks.
my optima yellow top weighed in at 45lbs the battery GM Muscle has is 13lbs like he said so 32 lb difference and if he says no problems its got my vote. Im buying one after christmas (waiting to see what I get ) Hope this helps.
Originally Posted by NOTFAST
Are there any batteries that work as well as a stock one but weigh less? basically, i need something that i can keep my bottle heater on and still start the car
With this battery you will not want to run the bottle heater without the car running (might be ok for a few minutes). However, my car has both underdrive pullies and it can easily sit idling in the lanes with the lights on and the bottle heater on and then restart no problem if I have to shut the car off for some reason.
Nate
Here's the battery I have: http://www.gotbatteries.com/Productp...ctNum=37L105S1
Here's how I mounted it: http://www.mustangmods.com/data/440/battery.jpg
I can go back to a factory style battery in about 10 minutes. With these adaptor arms I kept the same connecting bolts to battery.
Originally Posted by NA$TY-TA
HMMM thats got me thinking..... -32#'s there for me over my Yellow Top Optima. cant beat that for around a $100. Ill have to pic one up.....
Does it work any harder to start cars with the battery in the hatch like mine is???
Kyle
Kyle
Nate
Kyle
Kyle
Just install it up front, it weighs 13 lbs. Also it saves all the associated wiring and hassle with a relocated battery.
Originally Posted by Nate_Taufer
It probably wont be able to start the car in a rear mount unless you're running some stupid large batt cable. I wanted to do the same thing as well but all i came up with in the search function is that little batteries and remote mounting do not work well together.
Nate
Nate
Kinda hard to put a Battery back up front when this is in the way...
I do have 1/0 gauge wire ran from the front to the back...... so i cant get much bigger there I guess ill use the Optima i have until i just buy it and find out.
Kyle
