For a boosted app., which tuner?
Location: Tinker till it blows, then back it off a notch, maybe!!
Is EFI or HPT better for a boosted app (under 15 PSI) and maybe some NOS?
Not looking to start a war
TIA
TIA
EFILive will be releasing some nitrous specific Custom Operating systems soon this coupled with their boosted OS should do everything you want and more
http://www.efilive.com/forum/viewtopic.php?t=2638
I guess that I should have stated that I already own HPT.
I need to hook up a wideband and now I probably need to go to a 2 bar MAP, in that I need to flow around 1000 CFM and it seems cheaper to dump the MAF rather than try to find one that flows that much.
So with HPT, I need the enhanced interface and 2 bar SD upgrade.
I would have to learn either software
Chris...
Thanks for the P/N.
I found these in another thread
GM PN# 12223861 3bar MAP
GM PN# 16040609 2bar MAP
GM PN# 16137039 1bar MAP
GM PN# 15305891 - pigtail harness
So which 2 Bar will fit an 01 C5 vette, and is the harness needed?
