Christmas Specials!!!
Ok guys here are our Christmas specials... Merry Christmas
Group 1-
Our Famous Dual nozzle special..
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.Your choice in white or Black Bottle.(The Bottles will have NXs NEW 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value)
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Group 2
Now to make group one even more sweet....
Add the Dual nozzle special with a Adjustable,Automatic NX heater,purge kit,NGK TR6s and a Varible ramp Nitrous Controller for only 1060.20
Or subtract the Nitrous controller and add a Trick window switch and the whole package is 983.20
Group 3
How about a great stocking stuffer. Our pocket Bike systems have 25.00 off.
So now the single bottle is 185.00 and the dual bottle is 285.00
These are old pics.The actual system has real bottle brackets..
Group 4
THE 860 DEAL!!!!
For the guys not familiar with these products. These are the only ones like it on the market. The products are top quality..
Here is what is in the special.
1. The 860 heated Bottle bracket.This unique desighn is best desribed as a bottle bracket wth a billet heated hot plate all made in one. This unit has a adjustable pressure switch that will automatically control your bottle pressure.It also comes with a hex wing adapter and quick release bottle brackets. (NO wrench required to remove your bottle) This unit works well at retaining the heat just like a hot plate!!!! This unit normally sells for 199.00 for -4 and -6 for 207.00.
2. The 860 Bottle bracket mounting plate. This is a mounting plate that goes in the spare tire area so that you can bolt yuor bracket directly to the mounting plate out of the way.No drilling holes where every one can see.This unit normally sells for 45.00
3. The 860 Carbon Fiber bottle ****.This is a new product that was desighned to add a little style to your bottle and give you something to show your buddies.This unit normally sells for 35.00
This whole package is going for 239.00 for -4 applications and 247.00 for -6 applications.
Here are a few pictures.
THIS IS WHERE THE MOUNTING BRACKET FITS.
Group 1-
Group 2
Group 3
Group 4
THE 860 DEAL!!!!
Group 5
Our dedicated fuel systems are getting 40.00 off.
We have many to choose from. This is a example of one.
Group 6
Our NX single nozzle kit,NX adjustable, automatic bottle heater,purge,N2O Gauge,NGK TR6,and Varible ramp progressive controller. Only 975.00
Or Take out the prgressive controller and add the trick window switch and you new price is 898.00
Group 7
Nitrous Express 10 bottle jackets are 35.00 off of regular pricing.
10lb REG-118.80---Special-83.80 /15lb REG.132.99----Special97.99
Group 8
With the purchase of a Nitrous Express Maximizer recieve a FREE heater transducer and remote bottle opener controll module...Thats a 170.00 in free value all this for only 640.00
The groups missing pictures will have some shortly.. Do not forget that if you get the trick window switch in any package it puts you in for the drawing on the free plate..
STOCKING STUFFER IDEAS COMMING SOON.
Thank You guys for all your support and freindship.
Merry Christmas...
Dave
Group 6
Group 7
Group 8
Merry Christmas...
Dave
does the dedicated fuel system include any of the wiring and how do you wire it also can i get a fuel presure gauge mounted on the outlet of the regulator
Dave, I'm just curious about the NX blankets. I've always liked them but never really been close enough to get my hands on one and check them out. Why are they so damn expensive, is it the insulating material or something.
Dave
LOL,
I thought the same thing until I got one. The difference is deffintly big. The ones you see on the market for like 30.00 is just a thin material. Mostly for looks but does help. The NX blacket is like comparing a sheet to a thick quilt. I can not remember the material use. Ill find out and get back to you.
When you see one in person and try it it makes since.
Dave
Dave, on that 860 bottle heater/bracket can that be mounted on the raised spot behind the back seats? and what kind of price do you get on a dedicated fuel system for an fbody mounted in the battery location?
dave, has anyone test fit the mounting plate with a battery relocation box in the spare tire well yet? i know there was talk of people wanting to do this when the plate was first unveiled
Our price on the dedicated systems are 699.99. They are 40.00 off right now.
Thanks
Dave
I am not sure if it will fit or not.. Do you have some good pictures you can email me off your battery mounted there?
Dave
