T3 with .84 a/r or T4 w .81 ar
Old 12-02-2005, 08:17 PM
2002ws-6's Avatar
Default T3 with .84 a/r or T4 w .81 ar
T3 with .84 a/r or a T4 with .81 a/r
What would the real differences between these be? both have a p-Trim 64.5mm turbine? This has just been a question floating around my head for a while now, any help would be great.
Old 12-02-2005, 08:35 PM
Wet 1's Avatar
I'm not sure what you are looking for. The .81 ar T4 would flow more air and be less restrictive.
Old 12-02-2005, 11:24 PM
2002ws-6's Avatar
which one would spool quicker?
Old 12-02-2005, 11:28 PM
Wet 1's Avatar
T3 .84 a/r with all other things being equal.
Old 12-03-2005, 12:07 AM
93formto98T/A's Avatar
In theory the T3 will spool very fast but there's a good chance you'll max it out before redline. Go with the T4 and spool a little later but still have room for a great top end. JMO
Old 12-03-2005, 04:38 PM
FastKat's Avatar
Does a "faster spool" make the car any more difficult consistenly launch on street tires? Not sure if that would break the tires loose too easy or what... ?
Old 12-03-2005, 04:45 PM
Wet 1's Avatar
I belive the 64 or the 67mm with the T3 .84 a/r is one of the hot setups for the single turbo supra guys. I want to say the 67mm P trim with the .84 a/r T3 is good to about 650 rwhp. I'm thinking twins!
Old 12-03-2005, 05:08 PM
eviltwins's Avatar
None of the supra guys are running a single T3 housing, and they don't make T3 housings in .84 A/R.
FWIW I had a turbo manifold on my old civic that let you bolt up a T3 or a T4 footprint turbine. A .68 A/R PT67 P-trim on a T4 frame spooled up the same as a .82 A/R T3/T67 P-trim on a T3 frame, and the T4 version made even more power on the top end. Also, I would never put a single T3 turbine housing on a V8 motor, no question.
Old 12-03-2005, 05:15 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
T3 will spool quicker, have more backpressure and make a good bit less HP on a 67.
Like Evil said, Supra's are T4, and I personally would not bother running anything less then a T4 on a V8 single setup and preferably a T6 if you plan to make big hp.
Old 12-03-2005, 05:21 PM
Wet 1's Avatar
I thought Marko told me many of the Surpa guys were running the 67mm/T3 combo. I must be mistaken.
I agree with the above about not using the T3 housing for a single V8 turbo (assuming the T4 or T6 was an option). Now twin T3's on the other hand can be a nice setup.
Old 12-03-2005, 07:07 PM
I chose to go twin PT61S T4s with .69 A/R and 364ci. We'll see...
Old 12-03-2005, 07:10 PM
2002ws-6's Avatar
[QUOTE=eviltwins]None of the supra guys are running a single T3 housing, and they don't make T3 housings in .84 A/R.
The site I was looking at shows a MP t70 with your pick of A/R's T4 .68
T3 with .70 .84 .96?
http://www.turbocalculator.com/map-t...=Garrett%20T70
I'm planing on keeping 346 ci , custom cam that will pass Ca. smog and cats can't be moved. Not a Drag car, well it'll see some weekends maybe, Redline of 6000. 7-8 psi. If the T3 gets maxed out won't the extra backpressure go throught th waste gate??
Quick Reply: T3 with .84 a/r or T4 w .81 ar
