What's better, H or I beam connecting rods?
Old 12-02-2005, 09:18 PM
9 Second Club NA
Dragaholic's Avatar
Default What's better, H or I beam connecting rods?
I was looking at the Scat rods and the I beam are lighter and cheaper for some reason. Scat states that they H beam rods are stronger.
Old 12-02-2005, 10:33 PM
Beast96Z's Avatar
H-beams are heavier because they have extra meat on them, which makes them the stronger rod. I went with the SCAT H-beams in my build because they were lighter than most of the competitors H-rods.
Old 12-05-2005, 10:17 AM
MARKSZ71's Avatar
scat is ok but i would want callies
Old 12-05-2005, 11:08 AM
PREDATOR-Z's Avatar
I wouldn't worry unless you are building over 700rwhp N/A
Scat I's would be plenty. Just double check specs on rod bolts.
Old 12-05-2005, 01:25 PM
Bo White's Avatar
I searched it, remeber it being talked about before:
www.ls1tech.com/forums/showthread.php?t=237941
Old 12-05-2005, 06:18 PM
Ferocity02's Avatar
Pretty much any rod will be sufficient under 800rwhp. Over that you will probably want something a little stonger like Lunati.
Quick Reply: What's better, H or I beam connecting rods?
