Lifter Retainers
Lifter Retainers
Is there any reason to replace these things? The one i have seem ok, but i do not know what everyone is doing with them? Should I replace them or just reuse?
depends what you want to do... I chose to replace them just for piece of mind since its only 20 bucks for the set of four. I had a lifter go south, and Im scared to death about turning a liftere sideways. Not that these plastic retainers would make a difference, but new ones couldnt hurt, right? I think most people dont bother replacing them.
Originally Posted by Teutonic Speedracer
Some of mine had slop in them allowing them the lifter to rotate 10-15degrees. For $20...it's probably worth it. I upgraded to the LS2 ones and drilled the oil holes in the side (1/4").
Originally Posted by GuitsBoy
ls2 retainers work in the ls1, but the ls1 retainers dont fit the tls2 block
