Grand Am camshaft- Is notching pistons required on all install
Old 12-04-2005, 06:28 PM
GTS346's Avatar
Default Grand Am camshaft- Is notching pistons required on all install
With the GMPP Grand Am cup camshaft, is it essential to notch pistons on every install, eg. can you install on different centreline and get away without notching?
With stock heads.
Old 12-04-2005, 06:39 PM
SUTTERERMAN85's Avatar
the lift is low like .550 ish isnt it? if so then it would not be a problem i wouldnt think. its got lazy lobes not too much lift and it for a stock headed motor.
Old 12-04-2005, 06:46 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
What is the centerline on that cam? I don't think that you would need to on un-modified heads. I think that if we are talking about the same cam it is on .570/.570 on a 106°?
Old 12-04-2005, 07:24 PM
TAF Motorsports's Avatar
On stock heads its really close. I'd still notch it IMHO
239/251 .570 106ls
GTS346's Avatar
Yes 106LSA 239/251 with 0.570/0.570. The lift isnt the problem its the duration.
Old 12-06-2005, 05:29 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that thing will probably be fun to tune.
