timing on 2002 z28
Old 12-04-2005, 07:45 PM
zrater's Avatar
Default timing on 2002 z28
what kind of timing does the stock ls1,s like
Old 12-04-2005, 07:53 PM
SSpdDmon's Avatar
You can blend in 2-3 degrees up top typically so you peak at 27~28*. I started adding a little at 4000 or 4400 and increased the amount I added as I approached redline.
Old 12-05-2005, 11:18 AM
silverTA2002's Avatar
When I first started tuning, I added about 4 degrees across the board.
Then you log everything from part throttle to full throttle, to mid throttle in higher gears/etc.
Decrease where you get KR till you have no KR.
